Particular Alpha Bounce
COW Forums : Trapcode
Ari Grunzeweig
on May 5, 2008 at 9:58:03 pm
Hi there,
Is there a way to use the alpha of a layer as the boundaries to bounce off particles?
For example, in the linked image, I'd like to have my particles bouncing inside the red tube.
The red tube is an image with alpha created from a 3d program.
http://www.imaginationcreations.com/picture1.png
I saw an option in particular to bounce off the alpha of a layer, but I couldn't get that to work...
Any ideas??
Thanks in advance!
Ari Grunzeweig
Re: Particular Alpha Bounce
on May 5, 2008 at 10:46:21 pm
Nevermind. I've leanrt that what I am trying to do is not possible
Darby Edelen
on May 12, 2008 at 4:30:10 pm
You can do this in Particle Playground, which ships with AE. The effect renders much slower than Particular, but it allows you to set boundaries in which the particles will bounce around using masks.
Darby Edelen
Lead Designer
Left Coast Digital
Santa Cruz, CA
Ron Coy
on May 29, 2008 at 3:18:51 pm
you could just put a layer over the layer of the red object and make the dimensions the same as the inside of the red object, then have them bounce off the edges (I think...)
