Tradcode plug wont load
COW Forums : Trapcode
Dawn Fido
on Apr 24, 2008 at 9:16:05 am
Hi, a friend of mine is running After effects 6.5 on her imac (system OSX) and recently added After effects cs3. However, being the mac person she runs to with any technical questions Im completelly stumped with this one. There seems to be a problem with loading the Trapcode plugins. After effects 6.5 runs them perfectly, but when installed in After Effects 7 they wont list in the Effects panel. Ive tied putting the plugins lose in the Plugins folder, putting them in a Trapcode folder in the Plugins folder and also Ive tried installing them into common/mediacore folder. Can anyone help or advise something else, could this be a problem caused because shes running two versions of After Effects, although I personally dont have the same problem on my work 'PC' which is running both After Effects 7 and CS3 and Trapcode works fine in both of them for me.
Can anyone help?????
By the way, the operating system is NOT Leopard, which I also believe can cause plug in compatibility problems.
© 2018 All Rights Reserved
