enlarge 'form' image
COW Forums : Trapcode
Matthew Patience
on Feb 10, 2008 at 10:30:42 am
I have created an image with form, but I would like to scale it up for print(obviously retaining qualtiy). Are there any workiflows to doing this, as when I simply enlarge the canvas and the layer from is applied to the output changes dramatically.
thanks for any help you can give
timothy montgomery
Re: enlarge 'form' image
on Feb 11, 2008 at 12:26:31 am
Have u tried the continuously rasterize switch turned on?
Precomp the particle layer into the appropriate resize, then click continuously rasterize and scale up the precomped layer.
Matthew Patience
on Feb 11, 2008 at 4:00:59 pm
Thaks for the reply.
Yeah, I have tried that, but didn't worked. Just scaled the flat image.
I've found under the 'transform world' section a scale property, which does seem to do the right thing however the image leaves the boundary of the layer. I've then tried a grow bounds modifier, but with no luck.
Anneliese Dost
on Oct 15, 2008 at 1:40:09 am
since i had the same problem and found the solution (for me, anyways):
disable openGL rendering, and it works like a charm!
