has anyone got particular to produce similair results to particle illusions pyro packs?
COW Forums : Trapcode
jeremy
on Jan 7, 2008 at 4:35:36 pm
i haven't ever used particle illusion, so i am curious if it is possible to reproduce the fire that is in the pyro packs available for particle illusion in particular. has any one been successful at this?
jeremy webb
Re: has anyone got particular to produce similair results to particle illusions pyro packs?
on Jan 8, 2008 at 6:46:32 pm
alright so i found the aonfire preset over at trpcode-people, but am having troubles scaling it to be bigger, should i enlarge the precomps of the f map and rgba map and then compensate with the base form settings?
