Particular: Animate Emitter in 3D
COW Forums : Trapcode
Liesbeth van der Zee
on Dec 11, 2007 at 9:47:42 pm
Hi people of Trapcode,
It would be great if one of you would have the time to look at my question.
I made a Custom Particle: a Composition of layers, each layer a seperate word, 1 frame after another. Time Sampling: Random-Play Once.
So you see a particle of different words.
I'm trying to animate this 'particle of words' over the screen: they have to 'fly' over a building, through a door, etc. It really has to look 3D, nearby is big, further away is small, and when rotating in y-axe the closest part should look big and further away looks small (fish eye effect? I added a Camera).
*Question: what is the easiest way to do this?
I set position keyframes in the Emitter, but when rotating the Emitter the words don't rotate.
Then I tried to rotate the Solid layer itself (in which the Particular Effect). I have to set 3D-Positionkeyframes here to. This becomes very complex.
And I tried to Pre-Compose the Solid. This becomes complex to.
This is the link to my test:
and the Project:
It's called Test_Particular_NW.aep
Thank you for your help!
© 2018 All Rights Reserved
