Particular: Life and death...
COW Forums : Trapcode
Dr. Unken
on Nov 9, 2007 at 12:00:04 pm
I am struggling with the particular plugin. All I want to do is have a constant amount of particles - none of them popping up/dying. I've tried initially cranking up the birth rate to 200 then dropping it to 0 on the next frame, with the life set to 1000. Doesn't work. I am without a clue? Can anyone help? I realise I could duplicate each individual custom particle and place them where I want but time is of the essence...
graymachine
Re: Particular: Life and death...
on Nov 13, 2007 at 8:45:07 pm
Go into the "Options.." (at the top) and set the preroll to 100. This will start generating particles as if they have been emitting for 100% of the length of the comp prior to frame 0.
Then, make the life to TWICE then length of the composition (the earliest possible particle would be born 100% before frame 0 and live 100% beyond frame 0.. therefore it's 200% of the comp length).
You can make a simple expression to due this for the life which is:
thisComp.duration * 2
That should get you going in the right direction.
Harry J Frank
Freelance Motion Designer
graymachine.com
Dr. Unken
on Nov 16, 2007 at 2:15:53 pm
Thanks heaps Harry - worked a treat!!!!
graymachine
on Nov 16, 2007 at 9:24:01 pm
Also, the newly released "Form" is exactly about that: having a body of particles that are always "alive" rather than having life/death. You might want to check it out.
Harry J Frank
graymachine.com
