Particular
COW Forums : Trapcode
LGABoarder
Particular
on Oct 30, 2007 at 4:25:21 pm
Is there a way to set an anchor point for a particle? Also can I effect the particle rotation without changing the position. I'd like the wind effect but without actually moving the particles. Thanks.
ochobeeguy
Re: Particular
on Oct 30, 2007 at 4:59:29 pm
Instead of using a static image for the particle, create a comp with the animation and rotation you would like to see. Make sure you build that comp so that it loops. Then select that comp as your particle and set it to loop with a random birth time.
