A "pre-roll"option in Particular ?
COW Forums : Trapcode
luluontheroad
on Sep 16, 2007 at 4:06:05 pm
Hello,
I'm animating drops, and I'd like to cut the beginning of the animation, when drops are beginning to fall. Is there a kind of "pre-roll" option in Particular ? I'm looking for it, but I can't find it. What solution could there be ?
For the moment, I tried animating the layer transparency, from 0 to 100% during the beginning phase. But it doesn't work at all : all the drops are already on screen, whereas the layer has an opacity on 0 % !!!!
I hope you can help me to understand this mystery, and to find the "pre-roll" option.
Thanks ! :-)
Peder Norrby
Re: A "pre-roll"option in Particular ?
on Sep 17, 2007 at 11:51:15 pm
There is a "Pre-Run" in the Options screen.
Other than that, keyframing opacity of the layer should indeed work, I cannot see anything that would cause that not to work. Also, moving the in-point should work.
Peder Norrby / Trapcode
mark cookman
on May 29, 2015 at 4:28:43 pm
There is much out of date but potentially useful stuff here on the cow.
Just to update anyone who searches up this old thread: "pre run" is now under Particular>Emitter>EmissionExtras>PreRun
