Particular- wind on aux system only
COW Forums : Trapcode
finder0
on Sep 8, 2007 at 7:51:43 am
I am trying to use particular to grow leaves and then blow away in the wind. I have the primary particle die and spawn an aux leave which will blow away. I tried using gravity since they are adjustable seperatly and rotating the layer 90 degrees but then when the 3d camera moves it goes all wacky. I looked into using wind, but I cannot figure out a way to have the initial particle not move at all but give good movement and turbulence to the aux.
thanks!
