Particular and collapse transformations
COW Forums : Trapcode
Naveen Mallikarjuna
on Sep 6, 2007 at 8:19:36 pm
Quick question:
Just to be clear -- Particular in a nested comp will not work with a camera from the parent comp the way other layers in the nested comp do, once collapse transformations is clicked. Yes?
So, I have Child Comp, which has Layers A, B, and C. Layer A has a Particular effect on it. Layer B and C are switched to 3D.
I put Child Comp into Parent Comp, and add Camera 1 to Parent Comp. I hit the "Collapse Transformations" switch on Child Comp. Camera 1 will treat Layers B and C as if they are 3D. However, it won't treat Layer A (Particular layer) the same way. In fact, it won't affect it all. Right?
I hope someone can help.
Naveen
Peder Norrby
Re: Particular and collapse transformations
on Sep 7, 2007 at 3:51:13 am
Yes, it does not work with collapse transformations. A workaround that may work for you is making a slave camera where all properties are expressed to another camera (in another comp).
Peder Norrby / Trapcode
Naveen Mallikarjuna
on Sep 7, 2007 at 6:38:05 pm
Peder, thanks for the response. I'll go ahead and try ganging that camera. And thanks for your plug-ins. They are the literally the best!
