particle behind camera
COW Forums : Trapcode
SterlingY
on Aug 14, 2007 at 2:54:21 am
I need to simulate a camera moving through smoke, but no matter how much I change the Z depth of the emitter, there are always a couple particles lingering in front of the camera.
Any thoughts?
-Sterling
Peder Norrby
Re: particle behind camera
on Aug 14, 2007 at 4:35:07 am
There is no property named "Z Depth" so I'm not sure what you refer to.
There are of course many ways to simulate that. Either emit a cloud towards the camera, or fly the camera through the particles, or use Physics-Wind to blow the particles past the camera...
Peder Norrby / Trapcode
SterlingY
on Aug 14, 2007 at 6:38:52 am
Sorry about the confusion with "Z Depth." I meant "Position Z." My mind was stuck in 3DS MAX.
I will try some of the ideas you suggested.
Thanks for the quick response.
Cheers,
Sterling
agassi27
on Sep 11, 2007 at 2:32:40 pm
The above solution should work. You could also combine the solution, by moving the camera in and the smoke layer out. If you still find there's a couple lingering particles, a quick fix could be to lower the opacity at the end or mask out the very last lingering particles that you can't seem to get the camera past.
