3D Stroke moire pattern
COW Forums : Trapcode
alemon
on Aug 8, 2007 at 9:29:00 pm
I am creating an animation using thin lines in 3d stroke. The lines are repeated and curve over themselves. I am getting alot of moire pattern when I render. Any suggestions?
Peder Norrby
Re: 3D Stroke moire pattern
on Aug 9, 2007 at 1:59:51 am
There is a section in the manual on thin lines. It has to do with adjusting Feather, Advanced>Adjust Step and Internal Opacity for optimal results with thin lines.
Peder Norrby / Trapcode
alemon
on Aug 14, 2007 at 4:11:07 pm
I'm having some luck fiddling with those adjustments. When I downloaded the Trapcode filters, I'm pretty sure I didn't get a manual. How do I go about getting it?
