3d stroke+light?
COW Forums : Trapcode
3d stroke+light?
on Aug 5, 2007 at 2:40:09 pm
Hey !
Im doing this project where I want a 3d stroke to go around flying (as always ;) , but make it light other 3d layers(which are dark when the stroke isnt around) while its moving near them.
Is that even possible?
Im using the offset option with the 3d stroke to move it. can I attach some kind of light to it?
or would I have to do this manually?
Thanks in advance !
Peder Norrby
Re: 3d stroke+light?
on Aug 9, 2007 at 2:04:36 am
You could try copying the path into the Position property of the light and adjust timing.
Another route is to dupe the 3D stroke layer, set a big size, low opac, max feather and try to use that "glow" to light the other layers, possibly by transfer modes or using it as a track matte.
Peder Norrby / Trapcode
© 2018 All Rights Reserved
