Particular Probs
COW Forums : Trapcode
Matt  Clugston
Particular Probs
on Jul 9, 2007 at 9:46:11 pm
thanks for your input here guys, i dont need the particles to follow a light emitter in this instance.
Basically what im trying to acheive is some clouds roationg round a sphere, im using a PNG (the planet) as an obscuration layer so that the particles look like their going round it and then trying to rotate the emitters x-rotation so they revolve round the PNG - however - like i say, i can scrub the x-rotation back and forth and watch it work perfectly in the viewport, once i click the animate / clock icon i suddenly dont have the option to animate or even see the animation.
Peder Norrby
Re: Particular Probs
on Jul 10, 2007 at 5:16:35 pm
I'm afraid the only way to do that is to rotate the camera around the scene (parent camera to 3d null, keyframe Y rotation on null), not sure if it will work with an obscuration layer.
Peder Norrby / Trapcode
Peder Norrby
on Jul 10, 2007 at 10:45:27 pm
Should actually work with an obscuration layer if you parent the obscuration layer to the camera.
I've added a "rotate particles with emitter" function to the feature request for v2 :-)
QueJet
on Jul 11, 2007 at 3:11:38 am
WARNING, obstruction layers for large particles or a solid mass of particles looks bad, obstruction does not support transparency (which means it doesn't support anti-anilising)
If you don't set the edges up correctly then you will get some BAD results.
Image Hosted by ImageShack.us
