3D stroke: make the stroke go around objects without making the layer 3d
COW Forums : Trapcode
Martijn397
on Jun 17, 2007 at 4:43:36 pm
Is it possible to make the strokes go around in 3d space and go around other layers without making the layer 3d (which makes it loose its thickness in 3d)?
Best regards, Martijn M
Peder Norrby
Re: 3D stroke: make the stroke go around objects without making the layer 3d
on Jun 17, 2007 at 11:10:10 pm
Try two instances - using Camera>Z Clip, sandwithc other layer in-between, but you cannot move the cam much.
Peder Norrby / Trapcode
