using physics to move particles without changing the emitter
COW Forums : Trapcode
robinyapockets
on Jun 12, 2007 at 11:20:28 pm
Hey Everyone,
I was hoping someone could help me with question i have. how do i affect the particles using air, wind and stuff without affecting the position of the emitter. i am trying to have organic lines write out some type.
ie. Like the way Pierre Michel signed his "bandemo" at the end of his reel intro.
I appreciate any help I can get.
thanks
robinyapockets
Peder Norrby
Re: using physics to move particles without changing the emitter
on Jun 13, 2007 at 2:12:52 am
None of them affect the position of the Emitter... Explain your issue in more detail.
Peder Norrby / Trapcode
robinyapockets
on Jun 14, 2007 at 10:58:27 pm
I think i figured it out using light as an emitter, and another light as a motion path or using winds for the particle physics.
Is that what you would have suggested?
Is that how Peirre Michel animated the Bandeno type?
Thanks a bunch,
Peder Norrby
on Jun 15, 2007 at 9:41:20 am
that sounds possible.
you could try also adding some Physics>Air>Turbulence to get a fluid random quality to the motion.
robinyapockets
on Jun 22, 2007 at 5:40:34 am
thats for the feedback.
wanted to also ask, if there is a way to have the physics work on the particles at the end of their lifespan...so the beginning of the stream isnt affected as much as the end.
