Particular - One particle per layer question
COW Forums : Trapcode
Steve Sy
on Jun 2, 2007 at 7:02:55 pm
What is the best way to use Particular to get 'ONE' particle per layer/image...so that the images do not repeat.
Currently I have it set up as:
7 unique sequenced layers/images in a comp and then referencing the comp using particular as:
Custom:
-Layer comp
-Time Sampling Split Clip - Play Once
Number of Clips: 7
However I'm still getting repeating images even when I have the particles/sec @ 7.
Patrick Deen
Re: Particular - One particle per layer question
on Jun 29, 2007 at 7:36:17 pm
It doesn't seem to make sense to use a particle system when you only want seven none repeating particles in your project... What kind of effects are you aiming for?
