straglow's rays get cutoff
COW Forums : Trapcode
aliengreen
on May 22, 2007 at 8:36:01 am
I've created a heart-shaped mask and used Trapcode's 3D Stroke on it, animating it down the timeline by keyframing the offset parameter. My problem is when I apply the starglow effect, the rays are cut off by the mask's edges. What am I doing wrong (or is there a parameter I haven't gotten right)?
I'll appreciate very much any help on this, and here's a thanks in advance
green alien
Lord Scales
Re: straglow's rays get cutoff
on May 22, 2007 at 3:27:51 pm
Try alpplying Starglow to an Adjustment Layer with Comp Size
Peder Norrby
on May 23, 2007 at 2:40:01 pm
Should not need to use Adjustment layer- Trapcode 3D Stroke should *always* be applied to a comp-sized 2D layer.
Peder Norrby / Trapcode
