Particular - reverse explosion - how to do?
COW Forums : Trapcode
sans.otto
on May 13, 2007 at 11:19:11 am
Hi guys a need yoor help with the particular plugin!:)
I set the emitter with a layer. it's seems to explode the layer in thousands particles:)
But I want to make the opposite: from thousands particle to no-one, like a reverse-time but not reversed :(
How can I do?
thanks,
Andrea
Peder Norrby
Re: Particular - reverse explosion - how to do?
on May 14, 2007 at 10:16:38 pm
Easiest is probably to render out and then time-revers.
Or you could try keyframing Physics Time Factor.
Peder Norrby / Trapcode
Tomas Chlubina
on Jun 10, 2012 at 5:55:26 pm
For me worked to Pre-compose the solid (or any layer) with Particular plugin and then just set Time reverse layer for the new composition
