Starglow problems...
COW Forums : Trapcode
Imhere460
on May 10, 2007 at 12:18:57 am
Soo...I have some words on a solid and I have an adjustment layer that has the starglow effect on it. I have the solid layer with the words on it shatter. I have the adjustment layer with the starglow on it instead of putting it directly onto the solid so that the peices still have the glow effect while it is shattering. The problem that I have found is that when I put a background picture on the timeline, the adjustment layer adds the glow to it. I do not want this. I cannot just move it above the adjustment layer because that covers everything. Is there a way to make the adjustment layer or the starglow effect to only effect my solid layer with the words on it? Or is there another way to do what I want? Thanks For Helping!
kurt murphy
Re: Starglow problems...
on May 10, 2007 at 1:14:22 am
The Adjustment layer will effect everything below it... Your best bet is to pre-compose the text layer, then add Starglow to that....
hope this helps,
kurt murphy
