Rogue particles just seem to appear
COW Forums : Trapcode
Chris Huggett
on Apr 19, 2007 at 10:46:31 am
i have a particle effect, using a custom particle, and for some strange reason, random rogue particles just seem to appear for no reason. They are always aliased and are filled red or white. Its definately not a setting and seems to be an error.
The only way i can fix it is to reset the plugin and start again.
Im using version 1.5 on AE7.
Any ideas.
Chris
Peder Norrby
Re: Rogue particles just seem to appear
on Apr 20, 2007 at 6:19:54 pm
send me any strange AE project files and I will investigate:
peder.norrby (you know what) gmail /dot/ com
Peder Norrby / Trapcode
Peppe Tannemyr
on Apr 24, 2007 at 11:46:20 am
Hi, just seen the same problem!
Really hopes that it is a solution here! I am having a 3344 x 720 comp,that are to be chopped up for multiply screens, so adding a preset that I made ( with just sphere), using custom the problems shows up and also using "star (no dof)........
