Making 3D Stroke object loop
COW Forums : Trapcode
Chris Poisson
on Mar 27, 2007 at 6:30:36 pm
I have a nice little blip of light made on a circle path, by offsetting start and stop keyframes, Very nice, but it goes around once and stops. If I copy and paste the keys there's a gap for it to start up again. How to make the little bugger go forever? The loop checkbox does not seem to work.
Peder Norrby
Re: Making 3D Stroke object loop
on Mar 29, 2007 at 7:28:44 am
do not use keyframes on start and stop, just set the values you want to make the right size and then make it move using keyframes on "offset" - can go as high as you like...
and check the "loop" checkbox everything will be fine :)
hth, otherwise just ask again
Peder Norrby / Trapcode
