fly-thru of an expanding particle sphere in Particular 1.5
COW Forums : Trapcode
raystar
on Mar 14, 2007 at 1:30:31 pm
Greetings!
Have a question which extends an earlier post.. (milkymonty? i think) regarding a fly through of a spherical partical field, but not static. I have a spinning logo disolve and I want the particles to continue the spin as they extend outward I have used Milenium's camera spin in a pre-comp trick (thanx!) but I only get about 50 or 55 degrees before this looks forced, (unless I/m doing something wrong).
Is there no method for say a full rotation of expanding particles as in the 'illusion of 3D' movie from Digital Anarchy's Spheroid Creator 3D Assistant?
(http://www.digitalanarchy.com/3Dassist/distribute_spheroid.html (second from top))
Have the need for this effect, but not the buget.
any help = good help
thanx
sland_r
Re: fly-thru of an expanding particle sphere in Particular 1.5
on Mar 21, 2007 at 2:15:42 pm
Wouldn't it work if you just rotate the emitter while moving the poition towards the camera in Z-space provided you're controlling the rate of emission and speed at which it expands? Particular lets you do that effortlessly.
