From RG Support
COW Forums : Trapcode
From RG Support
on Mar 12, 2007 at 8:46:04 pm
i am setting up a wide shot showing an oil rig surrounded by water. i am using particular to make machine gun fire come from the rig and splash in the water. it looks great, tho i am finding it tricky to adjust the emitters. i have 4 or 5 in the comp, and i am trying to move one around. is there a way to turn off or solo an emitter short of changing it's name?
Peder Norrby
Re: From RG Support
on Mar 15, 2007 at 1:19:36 pm
please use appropriate subjects for posts, (from RG support has no real info).
if you by using multiple emitters mean you use Light Emitters you can set (keyframe) the emission rate using the Light's intensity setting.
otherwise clarify question.
Peder Norrby / Trapcode
© 2018 All Rights Reserved
