3D Stroke
COW Forums : Trapcode
rainboway
3D Stroke
on Mar 6, 2007 at 9:21:31 am
Does somebody know how it's possible to obtain with 3D Stroke the effects of Naligun's Adidas posted in the gallery?
I could never obtain a stroke that moves in the space around other objects exept by rotating the layer on its 3D x or y parameters, but in this case the stroke became flat and too narrow.
How can I do that? Please help me....
Michela
zuktoor2
Re: 3D Stroke
on Mar 8, 2007 at 11:25:34 am
Hi rainboway,
- keep the stroke as normal, don't "rotate the layer".
- do your animation as if the stroke was going around objects.
- mask out the parts of the stroke you don't want to see in your animation...
- That's it!
Mylenium
Re: 3D Stroke
on Mar 9, 2007 at 9:51:55 am
I knew I had forgotten something and sopmeone... (probably because the Trapcode site has s omany problems lately and I wasn't able to verify). Apologies. ;O) From what I recall, Zuktoor is more or less right. The effect itself is mostly used as a standard 2D Stroke, just with the additional benefit of the tapering. All the "perspective" is added by shaping the masks accordingly, then cutting out offending areas using matting techniques.
Mylenium
[Pour Myl
zuktoor2
Re: 3D Stroke
on Mar 11, 2007 at 1:50:02 am
Hi Millenium!
I'd like you to clarify the "zuktoor is more or less right...!?
Do you have another way to achieve that effect???
or may be is my bad english? (sorry I'm french)
thanks!
