creating camera flash bulb FX
COW Forums : Trapcode
Jim Wilcox
on Feb 28, 2007 at 7:59:34 pm
Can anyone point me in the right direction to create a BG plate simulating a dark stadium with hundreds of camera flashes going of with Particular. I can sort of get the lights layed out but having trouble with generating the random nature of the flashes. I'm sure I'm on the wrong track.
Mylenium
Re: creating camera flash bulb FX
on Mar 1, 2007 at 10:02:37 am
Not sure. Don't the random or split clip methods work for you or is it just not random enough? in that case simply use multiple layers of Particular and give each instance a different randome seed.
Mylenium
[Pour Myl
zuktoor2
on Mar 1, 2007 at 3:33:31 pm
Hi Jim,
just put a box as emitter type, your particle life at 0.2 and the velocity to 0...You'll get the flash effect you're looking for...
Jim Wilcox
on Mar 1, 2007 at 4:36:08 pm
That's what I am after. Thanks very much to you both for the help.
