Trapcode LUX troubleshooting
COW Forums : Trapcode
mathieumathieu
on Feb 23, 2007 at 11:47:30 am
Hi !
I've got a problem using Lux 1.0.1 on AEpro 7.0.1 on Mac (Dual-Core Intel)
When I play a ram preview I often experience a troobleshooting, AE freeze showing me the wonder-multicolored-pointer-wheel that doesnot stop, and force me to quit the application.
Is this a known bug of this plug?
Am I doing a wrong action or is it just a kind of "out of memory" problem ?
thanks for helping me.
mathieu.
Peder Norrby
Re: Trapcode LUX troubleshooting
on Feb 24, 2007 at 4:47:49 am
Using AE on MacTel computers is far from optimal since it has to run under rosetta. It should work but takes a LOT of memory and its quite slow. And to answer your question - there is no such known issue with Trapcode Lux.
Peder Norrby / Trapcode
mathieumathieu
on Feb 24, 2007 at 3:01:24 pm
thank for your answer Peder, I will pay attention on working slower when using a lot of "Luxed light", and just wait to use all this machine capacity
Peder Norrby
on Feb 25, 2007 at 1:28:01 pm
Nucleo Pro has showed some amazing results with all Trapcode plugs except Lux (since Lux is multi processor aware in itself). Once again I would like to clarify that AE7 on mactel, regardless of which plugs you use, runs under rosetta. What you really need (and we all do!) is a real mactel version of AE. When that comes out well make mactel versions of all our plugs and everything will be fast again :)
mathieumathieu
on Feb 26, 2007 at 9:34:31 am
Hello Peder,
I have understand what my real problem is, just have to sweat out with Rosetta.
thank for your answer and advice.
Mathieu.
