PARTICULAR 1.5 -VERY STRANGE PROBLEM WITH LICENSE KEY!!-
COW Forums : Trapcode
Timothy227
on Feb 19, 2007 at 11:20:52 am
Hi to everyone
i'm experiencing a strange problem with particular 1.5; sometimes while i'm working in after effects the license key magically disappear and the plugin looks as if it's unregistered.(it shows the "red X")
This occurs when i enter the option to modify the other emitter parameters, just a click and the key disappear, If i re-fill the key the plugin works fine till i close the application.
Tried to uninstall and re-install the plugin but this does not fix the problem, needed help!
My pc spec, AMD64 FX 3.2, 2G RAM, WIN XP SP2, AFX 7 PRO.
Thankyou
Mylenium
Re: PARTICULAR 1.5 -VERY STRANGE PROBLEM WITH LICENSE KEY!!-
on Feb 19, 2007 at 3:43:05 pm
Check your user permissions. You may not have enough priviliges to permanently write the key to the registry. The only other thing that could cause this is are hacked/ generated keys which can be found in certain dark places on the internet. >:-O But we all certainly hope you are not using those, or are you? ;o)
Mylenium
[Pour Myl
