Light emitters
COW Forums : Trapcode
Jeff O'Brien
Light emitters
on Dec 28, 2006 at 8:42:18 pm
I've got a light emitter that I'd like to add a second light to, but the particles come out identical to the first emitter and match in timing. Any way to change this? If I duplicate the solid and the light, all I get is more of the same...I need to set up a second effect, but have it look for something other than "emitter"...but this is set in prefs, which is global, yes?
thanks for any suggestions,
Jeff
Mylenium
Re: Light emitters
on Dec 29, 2006 at 12:25:18 pm
I don't quite get what you are trying to do, but just duplicate your Particular layer and habve it look for a differently named light. For this simply change the name string in the Options panel of Particular and then name your second light accordingly.
Mylenium
[Pour Myl
Jeff O'Brien
Re: Light emitters
on Dec 30, 2006 at 1:57:36 am
Thanks, I had mistakenly thought that the Options panel affected all instances of Particular...
Mylenium
Re: Light emitters
on Dec 30, 2006 at 11:43:01 am
[Jeff O'Brien] "Thanks, I had mistakenly thought that the Options panel affected all instances of Particular..."
No, lucckily not ;O). Each Effect only knows its own little universe.
Mylenium
[Pour Myl
