Render does not match my project
COW Forums : Trapcode
gfunk-gfx
on Dec 13, 2006 at 6:30:06 pm
I'm having a problem. I'm running through the Nano project to use this particle rays as a transition for a project I'm working on. The only problem is the render from my main machine does not match what I see in my viewport. But if I render from my laptop everything is fine. Is there a swtich somewhere? To see what i'm talking about go to this link.
http://gfxcreative.com/particularProblem.html
someone please help me. i really don't want to have to render this on laptop as separate elements to bring into my main comps. would like to work this out on my main machine.
Mylenium
Re: Render does not match my project
on Dec 13, 2006 at 9:34:43 pm
Mmh, it definitely looks like it's emitting too few particles in your faulty example. However, if the projects are 100% identical, that should not happen. Do you have the same version of Particular on both systems? (just a wild guess).
Mylenium
[Pour Myl
gfunk-gfx
on Dec 14, 2006 at 1:03:39 am
yeah, both are identical.
Peder Norrby
on Dec 14, 2006 at 8:09:24 am
Whenever the render does not match the RAM preview that means the problem is in the output settings like codec, interlace, best/draft etc.
Try render with "Current Settings" (assuming the RAM preview looks good) and a lossless codec and let us know.
Peder Norrby / Trapcode
