pb with particular
COW Forums : Trapcode
macviv
pb with particular
on Nov 23, 2006 at 11:15:37 pm
Hi
In a 3D scene, filled with layers in the Z axis, I build a "city". Far away in the background, I have some smoke coming out of a cheminee. This was made using lights as emitters with particular.
I am having rendering issues.
If the particular layer is at the lowest level in the timeline, something wired is happening and all the 3D layers in the forground are loosing their "hierachical attribut" and are now overlapping each others.
If I put the particular layer at the top, the smoke is overlapping all the 3D layers and doesn't have any depth of field.
The "obscure layer" can't help since I have several layers in the forground.
And for some reasons I can't want precompose anything
Mylenium
Re: pb with particular
on Nov 24, 2006 at 8:44:30 am
Pre-compose. In all honesty, there is no way around it. What you are doing is not Particular's fault, it's a limitation in AE itself - any 2D layer will "break" the rendering order of 3D layers. Put your city in a pre-comp and use it as a matte for the smoke.
Mylenium
[Pour Myl
