Disintegrating People with particular like the illusion tutorial
COW Forums : Trapcode
Frusta
on Nov 19, 2006 at 8:22:33 pm
Hi, i see the tutorial by Elvis Deane in the illusion section...
how to do it with trapcode particular?
http://forums.creativecow.net/cgi-bin/page_wrapper.cgi?forumid=23&page=http...
Mylenium
Re: Disintegrating People with particular like the illusion tutorial
on Nov 20, 2006 at 5:47:39 am
Use your actor as a layer/ layer grid emitter. Emit all particles at the first few frames, then fade out the actual layer and only the particles remain. The rest is then just a matter of tweaking the particle settings, most importantly setting layer sampling to "At Birth".
Mylenium
[Pour Myl
Frusta
on Nov 23, 2006 at 2:46:04 pm
Hi, ok for Emitter Type "layer", Layer Sampling "Particle At Birth" and Direction "directional", but when i tryed the emitter type in Layer Grid i see indipendent areas of particles...not so good...
Peder Norrby
on Nov 23, 2006 at 6:29:40 pm
Maybe use the Layer rather than Layer Grid mode (diffuse spread of particles instead of even grid).
Make them smaller in size and increase Particles/sec.
Peder
Peder Norrby
on Nov 23, 2006 at 6:30:57 pm
Also, check this brand new tut:
http://www.creativecow.net/articles/lee_james/particle_build_up/
Peder Norrby / Trapcode
Frusta
on Nov 25, 2006 at 5:03:20 pm
Ok, tnx a lot!
Amit Zinman
on Nov 19, 2007 at 6:19:22 am
I've follow these instructions and I still get a bunch of particles, nothing that reminds me of the layer :( Frusta, can you write here your exact settings?
