Emitter Y rotation doesn't works
COW Forums : Trapcode
Frusta
on Nov 14, 2006 at 2:03:51 pm
Hi, i have a problem, if i rotate my Y rotation without stop watch i can see the rotation, if i switch the stop watch and change value in 2 different keyframe it doesn't works...
Peder Norrby
Re: Emitter Y rotation doesn't works
on Nov 14, 2006 at 6:26:55 pm
It does in fact work, just not the way you want it to work :)
It rotates the Emitter so "old" (already emitted) particles are not affected. Try the Directional emitter type and you'll understand what it does.
For what you want the simplest way is to create a 3d null object, parent the camera to it and then keyframe rotation Y on the null.
Peder Norrby / Trapcode
Frusta
on Nov 16, 2006 at 4:35:55 pm
ok, now it works...tnx a lot! :D
