question re: trapcode particular --> fireworks
COW Forums : Trapcode
meg barbour
on Nov 14, 2006 at 3:39:47 am
I am creating fireworks with trapcode particular, and would like to know how (or if it is possible) to make fireworks that look like colored laser beams (straight lines) emitting from the center. Thanks very much, --Meg
meg barbour
the barbour shop
meg@thebarbourshop.com
Mylenium
Re: question re: trapcode particular --> fireworks
on Nov 14, 2006 at 7:05:44 am
Sure. Use grid emitters. The trick is to crank up the density of the grid. The solid itself can be very small. After that all you need is to use high emission rates to get a continuous stream of particles - each grid element will form one stream. Then just find a suitable velocity and Direction setting ("outward" should do the trick).
Mylenium
[Pour Myl
