simulating change in water pressure?
COW Forums : Trapcode
lightning ad
on Nov 13, 2006 at 10:25:44 pm
I am trying to replicate a real world situation where a jet of water is being fired out of a toy. As the jet finishes, the pressure drops and the arc of water reduces and falls off to nothing.
I have managed to get the jet under pressure looking right, but i cannot figure out how to change the pressure behind the emitter to give a usable fall off. I've tried lowering the velocity settings but that just seems to lower the speed.
Any ideas how this can be achieved?
Editor/Mixer
Character Options Ltd
Oldham, UK
Peder Norrby
Re: simulating change in water pressure?
on Nov 13, 2006 at 11:40:21 pm
keyframe down the velocity & particles/sec parameters should do it. you are using phyics>gravity already? if not, try it.
Peder Norrby / Trapcode
lightning ad
on Nov 14, 2006 at 10:34:11 am
Thanks Peder,
Reassuring to know I was already on the right lines but i think i needed to be more aggressive with my parameter changes. Its looking much more acceptable now.
thanks again.
