AE: how to make "dotted" zoom logo in particular (belief's zoom)
COW Forums : Trapcode
adiosudowo
on Nov 9, 2006 at 7:30:57 pm
how to create dotted logo like belief's zoom logo in trapcode particular? and how to make the pink petals, are they created in particular too?
many thanks
adio.s
Mylenium
Re: AE: how to make "dotted" zoom logo in particular (belief's zoom)
on Nov 10, 2006 at 7:00:11 am
To create the dotted/ rasterized logo (aka LED wall) use "Layer Grid" emitters. This way particles will inherit properties of the footage used as the grid layer. If you use the "Custom Colorize" in combination with a b/w custom particle, you can create al lkinds of effects including lens flare type stuff as seen in the clip. To bend your layers in 3D space, yuse other effects after Particular. It's easy to create circular backgrounds using CC Cylinder for instance.
The bands are most likely 3D, but you can create similar things by using multiple layers with low opacity, each of which has it's own Stroke/3DStroke effect applied and the mask shapes animated.
Mylenium
[Pour Myl
adiosudowo
on Nov 14, 2006 at 3:33:31 am
wow, thanks, it is works! very powerful plugin, yeah!!
