3D Stroke Combustion 4 NO PATHs
COW Forums : Trapcode
HashPop
on Oct 31, 2006 at 9:32:07 am
There seems to be no way to select a path from the 3D Stroke plugin in Combustion 4.
Could someone please explain confirm deny this is broken bug bad.
No Mask no animated path no nothing seems to show up as a valid selectable path to the 3D stroke plugin running in Combustion 4
Peder Norrby
Re: 3D Stroke Combustion 4 NO PATHs
on Oct 31, 2006 at 10:24:13 pm
If you download the pack for Combustion 3 it contains tutorials on how to use the products. Note that C4 is not offically supported, but I think it work there too.
Get it from the download page (Combustion3 Plugs & docs):
http://www.trapcode.com/download.html
Peder Norrby / Trapcode
jporter313
on Nov 2, 2006 at 10:44:31 pm
If I remember correctly, this is a major limitation in 3D stroke for Combustion. Basically all you can do is draw in your strokes.
