particular 1.5
COW Forums : Trapcode
kilmyneo
particular 1.5
on Oct 18, 2006 at 4:49:18 am
Can particular 1.5 work in Ae-6.5?
Mylenium
Re: particular 1.5
on Oct 18, 2006 at 5:32:56 am
Yes, it does.
Mylenium
[Pour Myl
kilmyneo
Re: particular 1.5
on Oct 18, 2006 at 3:52:20 pm
But when i install Particular 1.5 in AE 6.5 ... and open effects, its the same Particular there i have before V1.0, what im doing wrong?
Mylenium
Re: particular 1.5
on Oct 18, 2006 at 5:38:33 pm
Have you made sure you removed the old version from your plugins directory and copied/ installed the new one properly? Other then the additional motion path drop down you won't see much difference in the controls. The other improvements are contained in already existing options.
Mylenium
[Pour Myl
kilmyneo
Re: particular 1.5
on Oct 18, 2006 at 6:45:38 pm
ok, it works! :) ........but.... when i tried to use the motion path...and follow the steps of the tutorial, alway popup these message: The motion path feature needs a ligth to follow. could not find named
Mylenium
Re: particular 1.5
on Oct 19, 2006 at 6:02:16 am
Check your naming. It should be "Motion Path 2". Works without problems here.
Mylenium
[Pour Myl
