viewing 3d stroke in camera views
COW Forums : Trapcode
joe
by
on Oct 13, 2006 at 3:19:58 am
Is it possible to view 3d stroke in other camera views besides the active or front camera. It would be extrmeely helpful in laying stuff out if this were possible. I'm trying to have 3d stroke run through my 3d environment relative to other objects but its seeming to be highly difficult to get 3d stroke to run through properly
Mylenium
Re: viewing 3d stroke in camera views
on Oct 13, 2006 at 5:41:13 am
No. since it is dependent on masks (which cannot exist outside their 2D layer) that's not possible. If you are looking for a more elegant way, maybe you can try Particular with the Path Mode. It allows you to define real 3D paths using dummy lights and even correctly shows up in alternate views. ;o)
Mylenium
[Pour Myl
John Cuevas
on Oct 13, 2006 at 2:07:42 pm
Or the cheap workaround is to create extra cameras that mimic the camera views you need to look at. Just place them where they need to be, then turn them off until you need to use them.
Johnny Cuevas, Editor
http://www.ckandco.net
