Aux System Negative Values
COW Forums : Trapcode
Russ
by
on Oct 3, 2006 at 9:44:12 pm
When using the Aux system I need to put in negative values in some of the properties (Gravity, Wind). I select 'options and enter a negative number (say -10) the input is accepted, but the the visual response is incorrect.
When I go back and check the options I find that the -10 has been replaced with '65535'. These properties can be made negative with the main particles...why not the aux system?
Russ
Mylenium
Re: Aux System Negative Values
on Oct 4, 2006 at 3:21:50 am
That's a limitation you cannot really circumvent. Somehow it never works the way one would expect. Another kink to iron out for a future release, I suppose. ;o) If it's an option (and not too much work) use a duplicate of your layer and animate this duplicate's main particle emission to look like Aux particles.
Mylenium
[Pour Myl
