Random Custom Particules
COW Forums : Trapcode
giancarlo
on Sep 29, 2006 at 7:30:16 am
Hello,
It's possible to use more than 1 custom Particule to play in the same effect instance on a solid?
Example: in 1 solid, I would like to have 4 diferent (custom particule) logos images making the same animation together.
Thank you
Gian
John Cuevas
Re: Random Custom Particules
on Sep 29, 2006 at 3:52:09 pm
If I'm reading this correctly, then all you need to do is create a precomp with your 4 particles. Make each 1 frame long, make the composition 4 frames long.
Now place that in your main comp, set the particle to custom, then under Custom-time sampling, chose "random-still frame"
Johnny Cuevas, Editor
http://www.ckandco.net
