is there a way to get less than 1 particle per second in particular?
COW Forums : Trapcode
jeremy
on Sep 27, 2006 at 6:15:58 pm
if i type in 0.2 it gives me 1. is there a way to do this?
Mylenium
Re: is there a way to get less than 1 particle per second in particular?
on Sep 27, 2006 at 7:13:08 pm
No and I'm not sure if somewhere ou there is a particle system that would allow this - it's a mathematical paradox that cannot be solved easily (with cheating, that is). In your case you should try to slow down your comp/ footage by increasing the framerate or time-stretching your footage and once you have all your stuff set up, speed it up to normal playback speed again.
Mylenium
[Pour Myl
Peder Norrby
on Sep 28, 2006 at 11:05:02 am
Actually, the answer is YES.
Just click "Particles/sec" and type in the value numerically. (you can type 0.1 or 0.01 or whatever).
Peder Norrby / Trapcode
Mylenium
on Sep 29, 2006 at 9:20:08 am
It really does? Never even noticed that. ;O) but then again, I'm usually working more towards the opposite end of the scale...
Mylenium
[Pour Myl
