3D Cubes for Particles
COW Forums : Trapcode
on Sep 22, 2006 at 7:01:29 pm
I created a Cube with 6 Solids (50x50 size) at Compsize 50x50.Then new comp and a new solid with particular.I drag my "CubeComp" in that new one and select custom particles and chose my "CubeComp".My cubes have no more "deepness".It looks if it's only one solid.Not easy to discribe in english for me but you can the the effect in the top picture here:
I tried different ways with precomp my 6 cube layers etc. but always got the same result.i'm not expert in AE so please discribe easy if possible.Maybe Mylenium can explain in German.
Thanks for help
Peder Norrby
Re: 3D Cubes for Particles
on Sep 22, 2006 at 7:09:01 pm
Hmm, the cubes in the picture sure looks like cubes to me! They seem to have 6 sides and are shaded, so I'm not sure what you mean exactly...
Anyway, there is an example called "cubetrail" that you can download the AE project for here:
It has exactly the set-up you describe, 6 solids in a pre-comp used as custom particle.
Peder Norrby / Trapcode
© 2018 All Rights Reserved
