Creating grafitti ink splash with particular?
COW Forums : Trapcode
Erik.Ingman
on Sep 20, 2006 at 12:24:44 pm
Hi.
I've been searching the net for an AE plugin to create grafitti ink splashes, I can't find anyone but i was thinkin it might be possible with particle 1.5.0 from trapcode, just want to make sure, beacue it's some money to spend on a AE plu
Mylenium
Re: Creating grafitti ink splash with particular?
on Sep 21, 2006 at 5:25:00 am
It's not impossible, but since Particular has no coherence fields for particle-to-particle interaction as they would be required for real fluids, you'd need a lot of tweaking. Fluids are no trivial matter even in advanced 3D programs. You should take a look at Aharon Rabinowitz' Horror text tutorials. The techniques described there could be applied to your stuff as well and give some acceptable results.
Mylenium
[Pour Myl
zuktoor2
on Sep 22, 2006 at 12:40:28 pm
Hi Erick, check the blood splotches on the this site,
http://www.trapcode-people.net/
it gives you a starting point. I personnally reach a pretty realistic blood playing with particular and shade shape.
