PARTICULAR pROBLEM
COW Forums : Trapcode
Rajarshi
PARTICULAR pROBLEM
on Sep 2, 2006 at 2:00:16 pm
Im trying to multiply a group of people dancing using Particular.
But everytime Im getting a message
"Warning: Your custom particle layer size is big ( 1024*576)
...Im using PAL 720/576
andext message (It is recommended to keep size roughly between 20 and 100 pixels in both dimensions...)
Any help ?
Raj
Mylenium
Re: PARTICULAR pROBLEM
on Sep 3, 2006 at 2:12:01 pm
Particular will give this message to prevent you from causing crashes with too large particles. It should not stop you from working with large images, though. If it's an option, scale down your particles by creating a pre-comp with smaller dimensions. This will get rid of the message and shoiuld also render faster. If for some reason you can't follow that suggestion, try using AE's standard 3D layers and arrange them using the 3D Assistants (the lite version of which comes free with AE).
Mylenium
[Pour Myl
