3ds max to trapcode particular?
COW Forums : Trapcode
joejoejack
on Aug 21, 2006 at 12:46:03 pm
Someone please help me, how can I export max scene into after effects?
I have a 3D house in max and camera is circuling around so now I would like to add some fireworks around the house in AE trapcode particular with the same camera move and position...
please help
thank you
Mylenium
Re: 3ds max to trapcode particular?
on Aug 21, 2006 at 4:04:12 pm
You cannot easily import geometry in AE. Your only option is to convert your geometry to *.OBJ or *.3DS files from MAX and then render them in AE using Zaxwerks Invigorator Pro. Other than that you can of course always render an image sequence from MAX and use it in AE... Use that rendered sequence as an obscuration layer for Particular and you should get what you need. Your camera can be exported by Rendering RPF files from MAX and then using AE's Extract RPF camera assistant.
Mylenium
[Pour Myl
