Soundkeys affecting keyed rotation...
COW Forums : Trapcode
shirak23
on Jul 22, 2006 at 11:03:58 pm
I've keyframed a rotation of a layer in 3D space. How do I pickwhip or attach the soundkey "range" so that every time it hits the "beat" the layer will rotate to the parameters I have already keyframed. Hope I'm being clear enough. So, every time it hits the ranged beat it will rotate ONLY from degree "a" to degree "b" that I need. It's probably how it's written in the expression, but I'm an expression newbie.
Julius Caesar and the Roman Empire couldn't conquer the blue sky.
Mylenium
Re: Soundkeys affecting keyed rotation...
on Jul 24, 2006 at 5:23:53 am
Simply add your Soundkey output to the keyframed data. Something like this:
rotation+thisComp.layer("Soundkeys")("Output 1")
Mylenium
[Pour Myl
shirak23
on Jul 24, 2006 at 6:06:21 am
Thanks! I'll give it a try. I appreciate your help!
shirak23
on Jul 24, 2006 at 6:24:19 am
Hmm.. Doesn't quite work. It goes past the keyframe I have set. I am keyframing a rotation from 0 to 90 degrees and it goes past to 153 degrees. Also, it doesn't go back down to start again at 0, but starts the next rotation at 90 degrees. Any suggestions?
Mylenium
on Jul 24, 2006 at 5:02:58 pm
Adjust your output range in Soundkeys to avoid overshoot. As for the rest - well, Soundkeys can't reset your manually keyframed rotation, because it doesn't know anything about it. So you'd have to decide whether you want to control everything with soundkeys or manually keyframe complementary animation.
Mylenium
[Pour Myl
shirak23
on Jul 25, 2006 at 12:58:27 am
Okay, thanks again for all your help!
