Magnet effect Particular?
COW Forums : Trapcode
Rafael Macho
on Jul 14, 2006 at 7:38:24 pm
Is there any way to make the particules moving to a target point, like a magnet?
I want my particules to start from outside the comp and move to the center of the screen and stop slowly.
I created a matte layer hopind this would do in the "Emitteer Layer". In the Layer RGB Usage I set Lightness - Velocity.
I am affraid if I hit a limitation in this plug-in.
Mylenium
Re: Magnet effect Particular?
on Jul 18, 2006 at 6:02:29 am
No, there is no magnet, or more specifically targeting as you want it. You eitehr can time reverse a sequernce using the target as the emitter or you could try and use the radial force field.
Mylenium
[Pour Myl
Rafael Macho
on Jul 19, 2006 at 5:39:34 pm
That's what I thought, maybe in a next version... Thanks Mylenium.
