Particular - making a layer stick to the ground and stop rotation
COW Forums : Trapcode
Siesta
on Jun 22, 2006 at 10:24:23 am
I'm using Particular 1.0,
I want to animate custom particles that fall from the sky
and land on a floor. So far it's easy. The problem is that the
custom particles need to be rotated, and then obviously stop to
rotate when they hit the floor.
(I use a photoshop layer for the particles)
I've tried with "start at birth - play once", but there is to much
randomnes, so some particles rotate when they land, and others stop
to rotate in the air.
Anyone that has a smart solution?
Thanks for your time,
Per
Mylenium
Re: Particular - making a layer stick to the ground and stop rotation
on Jun 23, 2006 at 7:05:47 am
That's not really possible. you'd have to animate the custom particle to make the stop of the rotation coincide with the death of the particle which isn't very feasible.
Mylenium
[Pour Myl
Siesta
on Jun 23, 2006 at 7:39:55 am
ok, thanks.
It looks ok though when I stop the rotation on the custom particle after a few seconds.
Some of them continue to rotate a bit on the ground, but it's not to bad.
