How to make realistic clouds with slight movement in Trapcode Particular 1.5.
COW Forums : Trapcode
Pharhaan
on Jun 21, 2006 at 3:50:05 pm
Hi, there,
I want to know that how can I make realistic clouds with slight movement in Trapcode Particular 1.5.
Scenario:
Actually I am sequencing a clip in which camera will fly through out side the Planet Earth then simultaneously rip the clouds
and then there will be a satellite captured aerial view picture of earth and then it will more zoom in to reveal the product's name placed on the ground.
Kindly help me with this effect to make realistic clouds.
Regards,
Pharhaan Xapher
Mylenium
Re: How to make realistic clouds with slight movement in Trapcode Particular 1.5.
on Jun 21, 2006 at 4:58:47 pm
No. Sorry buddy, that's out of the scope of Particular, mainly because you won't be able to get the structure in the clouds the way you need. If it were just som backdrop elements, you'd get away with it but I don't think it will look too convincing from up close. You really should look into using stock photos/ footage for this - even the most simple selfmade shots will look more believable than anything you could come up with in Particular.
Mylenium
[Pour Myl
